Have the transmission flushed and have the filter changed, the filter could be clogging up, after you have it flushed and have driven it a while I would check it again and see how the fluid looks and smells, if it is ok then that would have taken care of the problem, do you tow anything with the car? If you do you might want to think about a external
transmission cooler.
SPONSORED LINKS
Sunday, March 11th, 2007 AT 9:28 AM
