transfer case pops out of four high
MIKE WEDDLE
i have a 98 trooper auto, well maintained. it started popping out of 4wheel dr. high, so i had the transfer case replaced and the vacuum switches on the front axle. nothing has changed. when i hit the shift on the fly button, i only drive a few feet, and the transfer case shifter handle will pop out of gear. am i overlooking something? please help. thanks, mike
Jan 5, 2006 at 12:36 AM
  • 55,588 POSTS
Once the transfer is in gear you can take it out unless you are at a stop, so that tells me there is a problem in the transfer case.
Jan 10, 2006 at 5:33 AM
