side door wont open
ROCKY_ROAD
  • 5 POSTS
Hi...I have a 1995 ford areo star and the side door wont open. I think it is the hindge but not shure. the spring is very twisted. I was woundering if any one knew how to pop the door open so I can put a new hindge or spring on the door. Please respond ASAP. Thanks very much.
Jan 4, 2006 at 9:59 AM
BONNIESBOYTOY
  • 11 POSTS
Rocky, you didn't state if the door has auto locks or if you tried pushing the door open from the inside (with your feet) with someone holding to door opening mech from the outside. I have seen the elect locks on only the pass doors die. There was a recall on Lincs a while back..Tom...
Jan 7, 2006 at 7:02 AM
ROCKY_ROAD
  • 5 POSTS
It hat no auto locks. the spring is twisted. yes i did try to push from the in side with my feet and some one did hold on to the handle on the out side.
Jan 7, 2006 at 10:13 AM
BONNIESBOYTOY
  • 11 POSTS
What do you mean "the spring is twisted"?? One side is loose and jammed around the hinge......Both sides are intack and twisted around the hinge..
Jan 7, 2006 at 12:00 PM
