Replace turn signal/combination switch
JMPERKINS
2000 Chevy Impala. 125,000 miles.
I purchased a replacement switch for the turn signal because the high beams wouldn't stay on. Does the steering wheel have to be removed to replace the turn signal lever? I found one site on the net that says its just a matter of removing two screws, dropping the plastic cover behind the steering wheel and then removing the switch. Is this correct or should I have a professional do it? I was quoted $130 to do it, but money is so tight right now and I have some mechanical experience.
EDIT-
I forgot to mention that this switch doesn't have the cruise control on it. The cruise control is on the steering wheel.
Nov 16, 2007 at 2:49 AM
DENNYP
  • 1,824 POSTS
you can just remove the covers behind the steering wheel to replace the switch.
Nov 16, 2007 at 9:57 AM
