Can anyone shed any light on what the cause might be?
Power loss & speedo drops to zero
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Give the shop the clutch-repair history and ask it to capture the speed signal and electrical supply during an actual fault. Inspect connections disturbed during the repair.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for loaded circuit testing; use matching vehicle specifications.
Discussion summary
The owner described intermittent loss of power with the speedometer dropping to zero, sometimes followed by stalling. The symptoms had been noticed since a clutch replacement. Another participant described a battery-cable problem on a different vehicle.
Reported outcome: No cause or repair was confirmed.
The timing after clutch work does not prove that the work caused the fault. A battery-cable anecdote and suggestion to search recalls were not verified for this vehicle.
