1987 Porsche 911 Turbo Boost Gauge Stuck
CRIDER
I have a 1987 porsche 911 turbo and love it the other day my boost gage began to rise even when it was not supposed to be spooling up. the day after to current when i turn the key the boost gage shows that it is spooled up all the way when there couldn't be any way that it could b/c the car isn't even running, then when the car is crunk the boost gage still shows that it spooled up all the way, when i reach the 3-4000 rpm mark the turbo does not kick in why is this doing this to me.
Jan 21, 2006 at 10:04 AM
  • 55,808 POSTS
Check the gauge it sounds like it is not working because is shows boost with out the car running, Next you could have a plugged exhaust system or a turbo that is failing for the performance issue.
Feb 1, 2006 at 4:32 AM
Suggested Repair
Check the boost gauge first, since it reads full boost with the engine off and is likely faulty. For the lack of boost around 3000-4000 RPM, also check for a plugged exhaust system or a failing turbo.
Conversation Summary
The owner of a 1987 Porsche 911 Turbo reports the boost gauge reads full boost with the key on and the engine off, and the turbo does not produce boost around 3000-4000 RPM. The expert says the gauge is likely not working because it shows boost without the engine running, and suggests a plugged exhaust or a failing turbo as possible causes of the performance issue.
