Outlet Valve Solenoid Malfunction
TKJEM
I have a 2000 Chevy Impala LS with a 3.8 V6. It is showing a fault code C1262 LF Outlet Valve Solenoid Malfunction. Where is it and how do I fix it.
Aug 28, 2007 at 6:25 AM
CLY
  • 308 POSTS
When you have that code setting as a current code then the electronic brake control module has an internal short to voltage for that cucuit. You must replace the Electronic Brake Control Module to solve your problem. The module does not require programing so you should be able to replace it yourself....
Cly
Aug 28, 2007 at 9:32 AM
