No running/tail/brake lights on 1995 S-10
BRIANWI
Only lights that work are the head lights and the amber lights in the front bumper. No tail lights at all in the back and the amber lights next to the headlights are also out.
What should I look for besides the switch in the dash?
Jan 10, 2006 at 10:03 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the correct fuse locations, feeds, grounds and lamp circuits checked using the truck's wiring information. Restore and verify brake-light operation before road use.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for testing loaded electrical circuits. Use the actual vehicle wiring and specifications.
Read the replies · Discussion summary and reported outcome
2CARPRO JACK
  • 11,533 POSTS
fuses
Jan 10, 2006 at 10:04 AM
BRIANWI
I checked the fuses in the side of the dash, all were OK. Is there another panel under the hood? I was unable to locate one.
Jan 10, 2006 at 12:33 PM
Discussion summary
A 1995 S-10 reportedly had no rear tail or brake lights and some front lamps were also out. The owner checked the dashboard fuses and asked whether another fuse panel existed.
Reported outcome: No failed component or completed repair was reported.
The fuse check lacked measurements, and no second fuse-panel location or switch fault was established.
Read the original discussion
