Merceses Benz 4matic
HAD TO REMOVE 4 MATIC CPU when they put it back i guess the connection was not quite correct i removed and replacxe re/re 4 amtic cpu and light went off hope it helps if your still interested
Suggested Repair
Scan the 4MATIC system for trouble codes and continue diagnosis from the results.
Conversation Summary
The owner of a 1992 Mercedes-Benz 300TE 4MATIC reported that the yellow 4MATIC warning light stayed on and suspected the system was inoperative. The control module and transfer case had tested okay, as had the other components already checked. An expert advised scanning for trouble codes and proceeding from those results. Another owner noted that a test lever can disable 4MATIC, the transfer case, and self-leveling. That owner also reported clearing a warning light by correctly reconnecting the 4MATIC control unit after overvoltage-relay service, and later by replacing the hydraulic and transfer-case fluids and bleeding trapped air at the test valve. The expert thanked the owner for the information.
