HELP! Prelude Won't quit serging
STEVESLITTLEGIRL
[color=darkblue:ce2f9fdbb0][/color:ce2f9fdbb0] :?: My 1986 Honda Prelude 5 speed 2.0 will not quit serging. We have done a full tune-up and taken it to a mechanic and had it put on a machine but no one can stop it. We also checked the vacume hoses. Please help with any :idea: info You have.[/img]
Jan 11, 2006 at 5:49 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the installed fuel and idle-control system identified and diagnose the surging using its service information before changing adjustments or applying cleaners.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
2CARPRO JACK
  • 11,533 POSTS
clean out the throttle bore with some carb cleaner.
Hondas vibrate the air bleed screw on the throttle bore. try turning it in to lower the idle
Jan 24, 2006 at 9:25 AM
Suggested Repair
Clean the throttle bore with carburetor cleaner, then turn the air bleed screw inward to lower the idle. On these Hondas, vibration can loosen that screw.
Conversation Summary
The owner of a 1986 Honda Prelude 5-speed 2.0 reports that the engine will not stop surging despite a full tune-up, a mechanic's machine diagnosis, and a vacuum hose check. The expert recommends cleaning the throttle bore with carburetor cleaner and turning the air bleed screw inward to lower the idle.
Discussion summary
A 1986 Prelude 2.0 manual continued surging after a tune-up, a workshop visit and vacuum-hose checks. A reply suggested throttle cleaning and changing an idle adjustment.
Reported outcome: No successful repair was reported.
The discussion did not establish an incorrect idle setting or a dirty throttle bore. The suggested screw adjustment was not verified for the actual system.
Read the original discussion
