1986 Honda Prelude Surging Idle
STEVESLITTLEGIRL
[color=darkblue:ce2f9fdbb0][/color:ce2f9fdbb0] :?: My 1986 Honda Prelude 5 speed 2.0 will not quit serging. We have done a full tune-up and taken it to a mechanic and had it put on a machine but no one can stop it. We also checked the vacume hoses. Please help with any :idea: info You have.[/img]
Jan 11, 2006 at 5:49 AM
2CARPRO JACK
  • 11,533 POSTS
clean out the throttle bore with some carb cleaner.
Hondas vibrate the air bleed screw on the throttle bore. try turning it in to lower the idle
Jan 24, 2006 at 9:25 AM
Suggested Repair
Clean the throttle bore with carburetor cleaner, then turn the air bleed screw inward to lower the idle. On these Hondas, vibration can loosen that screw.
Conversation Summary
The owner of a 1986 Honda Prelude 5-speed 2.0 reports that the engine will not stop surging despite a full tune-up, a mechanic's machine diagnosis, and a vacuum hose check. The expert recommends cleaning the throttle bore with carburetor cleaner and turning the air bleed screw inward to lower the idle.
