Heater Not Getting Hot?
1WILEY
My heater doesn't get very hot. The knob that turns the tempature to hot does not turn easily. Could this be the only problem, or does the thermostat need to be replaced?
Jan 10, 2006 at 1:57 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the knob and associated control movement inspected first. If the controls operate correctly, have engine temperature and heater operation assessed using the vehicle's service procedure.
Guidance references and applicability
Source: This question and its visible discussion. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
JOSEF
  • 6 POSTS
to see if your thermostat is working properly touch your upper radiator hose after the car has been running and warmed up for a period of time. if the tube is hot, then your thermostat should be good. you might need to replace your heater core to fix your heating problem.
Jan 10, 2006 at 10:23 AM
JEREMIAH
  • 217 POSTS
you didn't mention what car you have.
the linkage to the blend doors might be broken or stuck.it opens/closes the airway from the heater core.
see if there's any linkages under your center dash. like i said; you didn't say what car you drive.
Jan 10, 2006 at 3:24 PM
1WILEY
The car is a 95 Accord
Thanks for the info!
Jan 11, 2006 at 6:28 AM
MYDNGHT2U
Not sure if you still need help, but I had a problem with the heater not working and all it turned out to be was the temp knob on the dash. The knob was stripped and wasn't turning all the way to hot. Hope this info helps. :)
Jan 15, 2006 at 9:42 AM
Discussion summary
A 1995 Accord had weak heater output and a stiff temperature-control knob. Replies discussed the knob and heater-control linkage; another participant described a damaged knob on a different vehicle.
Reported outcome: The original owner did not report a completed repair.
The other participant's knob repair was not an outcome for this Accord. The discussion did not establish a thermostat or heater-core fault.
Read the original discussion
