fm modulator
DAVIDWRIG1990
Im thinking about installing a modulator for a satalite radio recever and it has a ciggeratte lighter adapter that you can install but Im not sure where to get the 12v from. Should I get it from the 12v from the radio or from the factory cigerate lighter main. The car is a 1992 Pontiac grand prix le and has the factory delco
Jan 3, 2006 at 1:14 PM
DAVIDWRIG1990
ok thanks ill do that then
Jan 4, 2006 at 11:40 AM
HOTWHEELSGMC
  • 31 POSTS
you could also get it from the ignition if you want it only when the key is on...
Jan 16, 2006 at 9:22 AM
