Fast idle
DREW0372
I have a 1994 4x4 5 spd ranger and when i first start it or when i push in the clutch it starts idling fast. I dont kno if its a bad sensor or what but can you help me out a little?
Jan 2, 2006 at 9:52 PM
DJ-TAINO
  • 12 POSTS
It can be the throttle control sensor or the IAC motor which is located next to the throtle body the sensor is located on top of the throtle body it is a plastic part whith 2 screws holding in place.replacing one of the 2 should solve the problem. It would help alot if you have someone do a diagnostic test on it .The test will show were the problem lies.
Jan 12, 2006 at 12:49 PM
