F-150 power door locks
JWSPROLES
The power door locks on my 2000 F-150 won't work from either switch. Both door locks will move slightly when the switch is hit in either up or down. Is it a relay or has both switches gone bad at once?
Jan 1, 2006 at 8:01 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have actuator movement and loaded electrical supply checked before selecting a relay, switch or actuator for replacement.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for loaded circuit testing; use matching vehicle specifications.
Read the replies · Discussion summary and reported outcome
JYOUNGIN1
most likely it is ur relay very rearly will both switchs good bad good luck
Jan 3, 2006 at 1:58 PM
JRC0109
  • 6 POSTS
Probably too late. But I had a similar problem with my '95 Windstar a couple of years ago. I had to use some silicone grease on each actuator.
Dec 23, 2006 at 11:31 AM
MATHIASO
  • 1,209 POSTS
In troubleshooting this system, first check both the gauge and the power fuses, next identify what component has failed.
you can either perform a continuity test or use a jumper wire to troubleshoot a single motor problem
Two other problems that can occur with a power door lock system are a failure of the ignition switch contact or failure of the main electronic control relay module
Dec 23, 2006 at 12:07 PM
Suggested Repair
Check the gauge and power fuses first, then identify the failed component with a continuity test or jumper wire. Possible causes include a failed ignition-switch contact or the main electronic control relay module.
Conversation Summary
A 2000 F-150 owner reported that the power door locks would not work from either switch, although both locks moved slightly when a switch was operated, and asked whether the relay or both switches had failed. One reply suggested the relay, and another described using silicone grease on the actuators of a different vehicle. The expert recommended checking the gauge and power fuses, then using continuity or jumper testing to identify the failed component, noting possible failure of the ignition-switch contact or main electronic control relay module.
Discussion summary
Both power locks on a 2000 F-150 moved slightly but did not complete their travel when either switch was used. Replies suggested a relay, actuator friction and electrical checks.
Reported outcome: No diagnostic result or successful repair was reported.
Another owner's lubrication result on a Windstar does not confirm the cause here. The thread's jumper instructions are not a vehicle-specific test procedure.
Read the original discussion
