evaporator drain line location
JIMBOG
I am getting water on the passenger floor when I run the AC . Where exactly is the evaporator drain line located on a 2002 impala. do you have to be under the car to get to it.
Thank you much.
Oct 15, 2007 at 11:06 AM
  • 75,988 POSTS
[quote:b5abe89dbf="jimbog"]I am getting water on the passenger floor when I run the AC . Where exactly is the evaporator drain line located on a 2002 impala. do you have to be under the car to get to it.
Thank you much.[/quote:b5abe89dbf]
Could be underneath the car or its in between the engine and firewall at the front passenger side.
Might also want to clean the cabin air filter
Oct 19, 2007 at 12:38 PM
