engine light
ROSEMARY356
  • 6 POSTS
2004 impala 66,000 miles 6 cylinder
My engine light keeps coming on. I replaced the gas cap. I had auto zone run the codes and they said I had a leak?? They reset it after I replaced the gas cap and within 4 days it is back on. What else could it be?
Aug 19, 2007 at 10:30 PM
SERVICE WRITER
  • 9,123 POSTS
The evaporative system has various components that may be failing. However it may also be a simple as a hose that has become disconnected or leaking. There may be a valve stcking or the neck leaking. The car needs to go to a shop that is current with the techniques of diagnosing this code. It may involve injecting smoke into the system or using a scanner capable of remotely controling the valves associated with the evaporative system.
Aug 19, 2007 at 10:43 PM
ROSEMARY356
  • 6 POSTS
[quote:75a4fd3502="Service Writer"]The evaporative system has various components that may be failing. However it may also be a simple as a hose that has become disconnected or leaking. There may be a valve stcking or the neck leaking. The car needs to go to a shop that is current with the techniques of diagnosing this code. It may involve injecting smoke into the system or using a scanner capable of remotely controling the valves associated with the evaporative system.[/quote:75a4fd3502]
Thank you very much, I will call today for an appointment :D
Aug 19, 2007 at 10:51 PM
ROSEMARY356
  • 6 POSTS
[quote:e459bb981c="Service Writer"]The evaporative system has various components that may be failing. However it may also be a simple as a hose that has become disconnected or leaking. There may be a valve stcking or the neck leaking. The car needs to go to a shop that is current with the techniques of diagnosing this code. It may involve injecting smoke into the system or using a scanner capable of remotely controling the valves associated with the evaporative system.[/quote:e459bb981c]
Aug 19, 2007 at 10:59 PM
