2001 Chevrolet Impala Auto Locks Inop
UKIE1
The locks due not operate when vehicle put in or taken out of gear. I have a 2001 Impala LS with 72,000 + miles, 3.8L I have checked the fuses and they are not burned out.
Aug 18, 2007 at 11:31 PM
SERVICE WRITER
  • 9,123 POSTS
Good morning Roman,
I believe there are 2 different fuses for that, but I am more inclined to think you can reset it as power is probably not the problem.
First Turn the ingnition switch to ACC or RUN position, turn the radio off.
Next, press and hold DISP button on radio for at least 10 seconds until SETTINGS is displayed.
Then you want to press SEEK up and down arrows until AUTOLOCK appears.
Then press PREV or NEXT buttons to scroll through options under AUTOLOCK. An asterisk will appear next to current setting.
To changeoption, dpay the option you want and press DISP button. A chime will sound to verify the new setting.
Lastly, to exit pres PREV or NEXT buttons to scroll until EXIT is displayed and press DISP button. You'll hear a chime to verify.
It's probably on mode 1, you want mode 4.
Aug 19, 2007 at 12:43 AM
Suggested Repair
With the ignition in ACC or RUN and the radio off, use the radio DISP, SEEK, and PREV/NEXT buttons to open AUTOLOCK settings and change the setting to mode 4, then exit and confirm the chime.
Conversation Summary
A 2001 Chevrolet Impala LS owner reported that the automatic door locks do not operate when the vehicle is shifted into or out of gear. The fuses were already checked and were not blown. The expert said power was probably not the issue and gave the radio menu procedure to reset AUTOLOCK, recommending mode 4 instead of mode 1.
