Aiming headlites
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Obtain the manufacturer's procedure for the installed headlights, including vehicle setup and beam references, or have a shop set the aim with suitable equipment.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis. HELLA: Headlamp adjustment https://www.hella.com/techworld/en/technical/automotive-lighting/headlight-adjustment/ General aiming and vehicle-setup background; use specifications for the installed headlamps.
The earlier six-foot wall-aiming measurements have been withdrawn because they were not verified for this Ranger. Use the manufacturer procedure for the actual headlamps, including the required vehicle setup, aiming distance and beam reference. If that information or suitable equipment is unavailable, have a shop set the aim. Arbitrary vertical or sideways offsets can reduce visibility or create glare for other drivers.
Discussion summary
Aiming headlites
The owner asked how to aim the headlights on a 1996 Ranger. Replies offered uncertain adjuster descriptions and generic wall-aiming measurements.
Reported outcome: No adjustment result was reported.
The unverified six-foot aiming measurements have been withdrawn. This discussion does not establish the correct adjuster tool or aiming dimensions for the truck.
