flasher relay?
J-DUB
flasher relay won't stop clicking. All the signals work fine, but the relay continuously clicks
Jan 5, 2006 at 10:46 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the clicking source and switch, flasher and lamp circuits checked using the wiring diagram for the actual vehicle. Record when the noise starts and whether operating the signals changes it.
Guidance references and applicability
Source: This question and its visible discussion. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
SMOKINFLOYD4.3
  • 56 POSTS
have you replaced it? if not, get one
Jan 5, 2006 at 10:51 AM
J-DUB
I don't think its the relay, being an electrician, I know that something has to tell the relay to engage. So I don't want to spend the money on one if I'm not positive that's the problem
Jan 5, 2006 at 2:09 PM
TGEORGE
Have you found any resolution to this problem because I have the same deal on my 1998 Blazer?
Mar 5, 2006 at 6:42 AM
NTMEANGREEN2003
I too have a '98 Blazer and started having the same problem about a month ago, but for mine the clicking stops when I apply the brake, what about with yours? I haven't been able to fix it yet.
Mar 5, 2006 at 9:25 AM
TGEORGE
ntmeangreen2003...yes my blazer does the same. Applying the breaks and using up that power does stop the flasher from ticking. I still don't have a solution though...
Mar 13, 2006 at 8:32 AM
Discussion summary
flasher relay?
The owner reported constant clicking from the flasher area while the turn signals still operated. The owner wanted testing before replacing the relay. Other participants described similar symptoms on their vehicles.
Reported outcome: The original owner did not report a repair.
Another participant's observation that braking stopped the clicking does not establish that behavior on the original vehicle. A faulty relay was not confirmed.
Read the original discussion
