'97 Grand Caravan Engine replacement costs
KIMBERLI_VIDA
I have a '97 Grand Caravan SE with a 3.3L engine. I was told the o-ring went bad, causing my engine to seize. How much can I expect to pay to have a used motor put in to replace the old one? Are there any considerations for determining whether or not to replace (vs. junking my van)? All else is functioning fine & it is in nice condition other than not moving. :)
Jan 5, 2006 at 11:24 AM
SCRAPER
Its between 15 and 20 labor hours. Pull your engine out swap manifolds, etc. and reinstall, If a shop is doing it, atleast in california thats between $65 to $100 per hour. Depending were you go. Shop around ask a lot of Question, check out the people that might do your job. and Good Luck. Tim
Jul 9, 2006 at 6:27 AM
