95 impala stalling
LUVMYSS
i have a 95 impala ss with 150,000 miles mods are team ss air cleaner home plate delete first base delete. i currently have an exhaust leak where the manifold meets cats. after driving 40 or so miles the check engine light comes on and the car stalls and will not immediately start. upon trying to start there a strong gas odor and the car will eventually start a repair shop said codes were no help.im not sure exactly what codes came out .should i buy a code reader myself or should i be replacing the most likely candidates maf, o2 sensors ,egr,pcv,or may exhaust leak be setting knock sensors retarding my timing .i could really use some sound advice.any help would be greately appreciated.
Sep 16, 2007 at 4:59 AM
J CAT
  • 5 POSTS
[quote:97b09740d6="luvmyss"]i have a 95 impala ss with 150,000 miles mods are team ss air cleaner home plate delete first base delete. i currently have an exhaust leak where the manifold meets cats. after driving 40 or so miles the check engine light comes on and the car stalls and will not immediately start. upon trying to start there a strong gas odor and the car will eventually start a repair shop said codes were no help.im not sure exactly what codes came out .should i buy a code reader myself or should i be replacing the most likely candidates maf, o2 sensors ,egr,pcv,or may exhaust leak be setting knock sensors retarding my timing .i could really use some sound advice.any help would be greately appreciated.[/quote:97b09740d6]
IAC idle air control is dirty but you must first patch the exhaust leak so the pcm will operate the engine as built LT1 does not like incorrect exhaust back pressures too high or too low.
Oct 13, 2007 at 2:13 PM
