327 suffix code
1932 CHEVROLET IMPALA
ROBCAS47
my project right now is to take a 327 out of my 1966 Impala and install it,(after rebuild), into a 1984 Monte Carlo SS. the casting number on this engine is 3858180. now i've done as much research as i pssibly can on the suffix codes and the only thing i can't figure out is the suffix code HC at the end. the full code is TO114HCH. i know this will help me figure out what this engine can make for HP/TQ. i would like to start out with a refrence of where i'm starting out with before the build. thanks for any help you guys can give me.
Apr 17, 2007 at 2:06 PM
MIKE D IN MD
  • 27 POSTS
my motor manual (1971) shows 327 w/ pg for a full-size chevy. 3 hp/tq ratings-----350hp/360tq, 300/ 360 & 275/355--all 4 bbl. mortec.com shows the casting # to be a 2 bolt main. on their site are head numbers as well. 2 engines are 10.5/1 and the other is 11/1 comp ratio- you may want to lower that for the street ( depending on how much you are going to drive it) today's cam & head tech are worth considering over a simple overhaul.
Apr 20, 2007 at 10:50 PM
