2008 Chevy Impala sensor
NOFUN75
Tires and Wheels problem
2008 Chevy Impala 6 cyl Two Wheel Drive Automatic
the light turn on and its the right front tire and its reading that it low but we put air in it and nothing happen how do we check if its the sensor thats acting up and replace it
Apr 27, 2010 at 3:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
did you fill up to the proper level? if it is then the sensor is bad, it will have to be removed and replaced as part of the valve stem.
Apr 28, 2010 at 6:42 AM
NOFUN75
can we replace the vavle stem and can we order it at the parts place like auto zone -auto parts
Apr 28, 2010 at 9:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
yes the auto part store should be able to order it overnight. i believe it runs around $50 and probably another $10 at a shop to have it replaced.
Apr 28, 2010 at 10:03 AM
