Power seat switch replacement
MIKE MUSKO
Electrical problem 6 cyl Front Wheel Drive Automatic
replace power seat switch on driver side
Oct 11, 2009 at 3:00 PM
  • 55,627 POSTS
The job is not bad you can replace the switch in about 15 minutes. Here is a guide to show you what you are in for when doing the job.
https://www.2carpros.com/articles/seat-position-switch-replacement
Here is how it will be like on your car (below)
Cheers, Ken
Jan 17, 2018 at 11:00 AM
CHILLINGWORTH68
Hi Ken,
How do you remove the levers shown in your photo attached?
Thanks!
Jan 25, 2020 at 4:23 AM
The photo didn't attach. If you can try again I am sure we can figure it out with you. Thanks
Jan 25, 2020 at 6:21 AM
  • 55,627 POSTS
Can you take a picture of the lever? It must have a screw in the middle under a cap?
Jan 26, 2020 at 2:21 AM
