2008 Chevy Impala check engine light and reduced engine pow
80,000 MILES • V8 • 2WD • AUTOMATIC
PENNYPOOH52
A scan showed an O2 sensor code. These lights having been coming on and off for about 2 weeks. The car slows down when the reduce engine power light comes on. Is this likely to be a serious repair cost? The car has been well -maintained and oil changes have been on time. All gauges work while this is happening , just the car slows down. What could be causing this on such a fairly new car?
Jun 20, 2010 at 1:32 AM
  • 75,988 POSTS
Did you replace the O2 sensor? if not do so and go from there-also rescanned the computer
Jun 20, 2010 at 9:22 PM
