2008 Chevy Impala
56,000 MILES • 6 CYL • FWD • AUTOMATIC
CHAVEZEMT
Why is my car overheating? I alredy changed the thermostat.
Jun 15, 2010 at 4:31 AM
RENAUDTN
  • 636 POSTS
Beside thermostat, it could be:
*Low coolant: external leak (inspect carefully all the hoses, thermostat housing, water pump, intake gasket, radiator, etc), internal leak (coolant in oil or vice versa, transmission fluid in coolant, a lot of white smoke coming out of tailpipe, all signs of internal leak).
*bad water pump
*Clogged system (flush)
*bad hose
*bad tensioner/loose serpentine belt
*cooling fans don’t come on
*bad radiator cap
*wrong timing
Pressure test your cooling system; that’ll tell you if you’re dealing with a leak.
Jun 15, 2010 at 9:14 AM
