2007 Chevy Impala when key is turneb no action from starter
45,000 MILES • 6 CYL • FWD • AUTOMATIC
MARKAGRIFFY1
Whe you inscert the key and turn it the radio comes on the info message says traction control off. if i disconnedt the pos cable the problem is solved until the car sits over night, the dealer has replaced the pos cable but this did not help
Sep 19, 2010 at 1:03 AM
HMAC300
  • 48,601 POSTS
if you bought the warranty with this car it should still be covered. But go to your underhood fuse box on the right strut and check your fuse and relay. It wil be clearly marked on the inside of the cover....
Sep 19, 2010 at 9:43 AM
