2007 Chevy Impala heater temperature
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARTELCCM
engine temp normal takes long to get hot air once i get hot air temp goes to cool then back to hot
Sep 17, 2010 at 12:59 AM
WRENCHTECH
  • 20,760 POSTS
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch.
If they are both hot, the temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Sep 17, 2010 at 1:10 AM
WRENCHTECH
  • 20,760 POSTS
Where did you copy this nonsense from?
Feb 6, 2011 at 2:42 PM
