Engine temp normal takes long to get hot air once I get hot air temp goes to cool then back to hot
Friday, September 17th, 2010 AT 7:59 AM
WRENCHTECH
MECHANIC
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch.
If they are both hot, the temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
