2007 Chevy Impala Accelration
70,000 MILES • 6 CYL • FWD • AUTOMATIC
PAMELAD82S
On my 2007 Chevy Impala, when I push on the gas to go, the car does not move, but the engine revs up. Then all of a sudden the car will jerk and then go. What could my problem be?
Sep 13, 2010 at 3:09 AM
  • 75,988 POSTS
If it's not slipping-see below:
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 13, 2010 at 10:35 AM
