The drainage line on my Impala (underneath on the engine compartment), keeps getting clogged up, and the water is draing from the firewalll area onto the passenger side floor.
HELP!
Saturday, August 22nd, 2009 AT 1:39 PM
HMAC300
MECHANIC
Take a small rod the size of a coat hanger and stick it through the bottom of the drain hose. Twirl it around or back and forth in it and run the rod/wire up and down a little. That should take care of it.
