2006 Chevy Impala pulsating brakes
2006 CHEVROLET IMPALA
44,000 MILES • 6 CYL • FWD • AUTOMATIC
DAN CARO
1000 miles are on the new pads and rotors. I had the same problem with the old pads and rotors.After having this new set put on they started to pulsate after 900 miles.Would putting quieting gel on the backs of the pads possibly cure the problem? What else could I try?
Thank You DAN
Apr 22, 2010 at 11:43 AM
RHALL77
  • 3,361 POSTS
check and see if there is any rust on them first. i would see if they are under warranty also. they may take care of it. Did you do the job yourself? If so, make sure you dont over tighten the lug nuts, this can and will warp a rotor.
Apr 23, 2010 at 1:45 AM
