2006 Chevy Impala Engine Light ON
78,000 MILES • 6 CYL • FWD • AUTOMATIC
BAXA
My Engine light is ON, got it checked by a Computer Code machine, they say not a major problem but something to do with Gas Evap or temp change.
Apr 7, 2010 at 2:24 AM
LEGITIMATE007
  • 5,121 POSTS
do you have the trouble code? so I can look it up
Apr 7, 2010 at 2:30 AM
BAXA
The Code is 496
Apr 7, 2010 at 2:39 AM
LEGITIMATE007
  • 5,121 POSTS
thats strange, I dont have that code in my refferences, are you positive?
Apr 7, 2010 at 3:00 AM
BAXA
Yes, the code in my invoice mentioned by the garage is
po496 EVAP SYSTEM FLOW DURING NON PURGE,
MANIFOLD FLOW TO THE EVAP SYSTEM
HAD UNDESIRED INTAKE
BARO PRESSURE ABOVE 74 KPA
GAS CAP NOT CLOSING PROPERLY
POSSIBLE PRESSURE LEAK
I hope that suffice, can you please help on the matter?
Apr 7, 2010 at 3:22 AM
LEGITIMATE007
  • 5,121 POSTS
ok ,let me ask you this, when you close your gas cap, do you keep turning it until it click,click, clicks, or do you just turn it until it stops?
Apr 7, 2010 at 5:04 AM
LEGITIMATE007
  • 5,121 POSTS
also I need you to check/change the mapp sensor
Apr 7, 2010 at 5:07 AM
BAXA
Your question about the Gas Cap,
Yes I try to close the Gas Cap I turn until it gives the Click, click sound - maybe 2 times, but it should be turned how many times is not clear as the Gas Cap can be turned even after 2 turns clockwise, so I normally stop turning to avoid breaking the cap.
About the Map Sensor - Please guide me how and what to check and report back to you.
Your help is highly appreciated.
Apr 7, 2010 at 9:43 AM
LEGITIMATE007
  • 5,121 POSTS
it wont break so a few clicks is fine, but you may have to replace it, it might not be holding pressure. the mapp sensor is located at the back of the intake manifold, usually like right in the middle, it has a little diaphram on the inside, check the vacuum hose going to it for cracks or it being flat and dilapidated. also, you can probably unhook it and see if you can blow, compressed air through it and clear it of any dirt oil/debris. if its caked up with dirt/oil then just replace it and then change the pcv valve too, because that is the reason why its caked up, is because the engine isnt venting properly
Apr 7, 2010 at 2:55 PM
