2006 Chevy Impala COOLING SYSTEM
TORULES2008
  • 2006 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 35,000 MILES
HI-MY DAUGHTER'S CAR IS GETTING A MESSAGE ENGINE HOT, A/C COOL & THE TEMP. GAUGE READS COLD. SHE JUST HAD THE 'STAT CHANGED AFTER THE SAME SYMPTOMS. ANY IDEAS? ANOTHER FAULTY 'STAT? THANKS-T
Thursday, May 1st, 2008 AT 2:59 PM
PAMIKE63
Just a minor correction, the Hill Descent Control is used in first or reverse, not fourth. That being said, the most likely problem is either a failed tranny or possible trans sensor. Given the fact that you are fed up and possibly looking to trade, I would support you going that route. If you decide to keep it, it requires having the codes read to determine what action should be taken next (replacement of sensor(s) or transmission replacement). Good luck.
Thursday, May 15th, 2008 AT 6:17 PM
