2005 Chevy Impala trac control and noise
GORDSEURY
  • 2005 CHEVROLET IMPALA
Steering problem
2005 Chevy Impala 6 cyl Front Wheel Drive Automatic
when I start my car from cold start and make a sharp turn when leaving the driveway a growling noise is heard in the front end and my traction control lite comes on. When warmed up it goes away.
Wednesday, September 24th, 2008 AT 3:28 PM
RHALL77
  • 3,361 POSTS
Have is checked for trouble codes and get back to me
Wednesday, September 24th, 2008 AT 4:20 PM
GORDSEURY
  • 5 POSTS
I cannot get a code, a mechanic says that a wheel sensor may be at foult
Tuesday, September 30th, 2008 AT 3:15 PM
RHALL77
  • 3,361 POSTS
Why cant you get a code.
Tuesday, September 30th, 2008 AT 3:46 PM
GORDSEURY
  • 5 POSTS
Don, t have a code reader, the only garage in my area dosen, t have one yet
Saturday, October 4th, 2008 AT 9:21 AM
RHALL77
  • 3,361 POSTS
Check out the 2 car pros store, they have them in there
Monday, October 6th, 2008 AT 7:57 AM
GORDSEURY
  • 5 POSTS
No 2pro car stores here, I am in nova scotia, canada, the only gm garage will charge me $65 dollars to perform a scan check, that, s too much for me, on pension. When I turn off the trac. Control when I pull away from a stopped position the problem is gone, only there when trac. Control is on. Was told it is a bearing sensor, loose wire or a wheel bearing is going bad
Thursday, October 9th, 2008 AT 5:04 PM
RHALL77
  • 3,361 POSTS
Most likely it is a bad wheel bearing or a broken wire. I just like to verify the code and what the problem is before I throw parts at it. That could get more expensive than just having someone see what the code is and fixing it correctly
Friday, October 10th, 2008 AT 10:30 AM
GORDSEURY
  • 5 POSTS
Thank you, i, ll check out both front wheel bearings and the sensor wires, gord
Saturday, October 11th, 2008 AT 7:13 AM
AUSTINCR
  • 6 POSTS
I'm no help but I had the same problem with my 2003 Impala.
When I turned left with my trailer on the car the trac light came on.
I pulled over, stopped the engine and restarted. This put the light out 'till next time.
The problem is gone for the past two months.
I'm also in NS. Outside of Truro.
Austin
Friday, October 17th, 2008 AT 8:47 AM
