2005 Chevy Impala radiator
2005 CHEVROLET IMPALA
CMIREE
Engine Cooling problem
2005 Chevy Impala 6 cyl Front Wheel Drive Automatic
I attempted to have my radiator flushed and nothing would come out of the drain plug. What can i do to fix this?
Sep 23, 2009 at 12:44 PM
LOUT5369
  • 217 POSTS
What you could do is,put a cooling system pressure tester on the radiator,open the drain,then pressurize the system,the pressure should clear the drain,after it clears the drain,pour a pot of boiling water into the radiator slowly that should melt away the clog.
Oct 3, 2009 at 6:06 AM
