2005 Chevy Impala power window
61,000 MILES • 6 CYL • FWD • AUTOMATIC
NORRIS
The window on the driver's side fell completely to the bottom of the door. I removed the door panel and could only lift the window about 2 inches with my hand. I could feel the cable was holding the window, but I could not free it. I removed the screws that mounted the motor and was able to free the cable enough to slide the window to a fully closed position. Now i need to know exactly what is wrong and how to repair it. The motor will try to move a little but that's all. I can't tell how the cable works or how it is attached or how to remove it if i need to replace it.
i
Oct 12, 2008 at 1:13 PM
RHALL77
  • 3,361 POSTS
sounds like you need to replace it. you can either purchase a manual or have a professional do it
Oct 13, 2008 at 1:28 AM
