2005 Chevy Impala New Rotors and Pads grinding...
110,000 MILES • 6 CYL • FWD • AUTOMATIC
DEMETRIUS17
I just put new rear rotors and pads on (disc brake) last Friday and I'm getting a scraping/grinding noise coming from the rear(as far as I can tell only the rear passenger) it only does it when I'm at very low speeds like rolling to a stop, What could be causing this?
Feb 24, 2009 at 6:52 AM
RHALL77
  • 3,361 POSTS
check and make sure there is nothing bent and scrapping on the rotor. also are you sure you have the ebrake in there correctly
Feb 24, 2009 at 7:25 AM
