2005 Chevy Impala low tire pressure light stays on
2005 CHEVROLET IMPALA
124,000 MILES • 6 CYL • 2WD • AUTOMATIC
USMC.CPL90
the low tire pressure light stays on even after tires are inflated to right psi
Jul 12, 2008 at 4:50 PM
KLM77US2
[quote:b6c87c6c2c="usmc.cpl90"]Tires and Wheels problem
2005 Chevy Impala 6 cyl Two Wheel Drive Automatic 124000 miles
the low tire pressure light stays on even after tires are inflated to right psi[/quote:b6c87c6c2c]
1) Put the key to on (but don't turn on thr car) push the stalk (dimmer) in all the way.
2) Pull the stalk out to the middle postition (not all the way back, go out 1 click, not 2) and back in like 3-5 times (you might or may not har a beep i do
Jul 20, 2008 at 3:31 AM
LNEWSOME
i have a 2001 impala, and after airing up your tires, you have to reset the warning light. I don't know how yours is set up, but mine is set up through the radio. you have to turn the radio off and hold the display button down until it gives you the settings options and then just scroll thru until you get to the tire setting and tell it to reset. it won't come on again until your tires are low again.
Aug 21, 2008 at 10:58 PM
