2005 Chevy Impala leakge
70,000 MILES • 6 CYL • FWD • AUTOMATIC
SANITY
Our car leaks fluid. There is a puddle of antifreeze underneath, but when we go to add water or coolant, the radiator seems full and overflows if we add more. We can't seem to find where it is leaking from. Also the heater stops working and when we add a little antifreeze (as much as we can fit) it starts working again but only if we add the stuff we buy from Napa. If we buy it from a c-store or Walmart it doesnt make the heater work. Do you have an idea of what the problem is?
Dec 12, 2009 at 10:12 AM
MMPRINCE4000
  • 8,548 POSTS
The leak is causing an air pocket in system, or there is a blockage in radiator/system.
Have the cooling system pressure tested to isolate leak.
Dec 14, 2009 at 12:12 AM
