2005 Chevy Impala Gas smell coming from engine
68,000 MILES • 6 CYL • FWD • AUTOMATIC
D73JESTER
  • 6 POSTS
I recently had some work done on my coolant system and they had to change my thermostat which requird them to remove the throttle body. I finally had a second and traced the smell, and fuel leaking on this component. When I start the car up fuel begins to pool on the rim and the vibration of the engine shakes it to the engine block where it burns off and I get fuel smell in the cabin of the car. I have circled the component. I have no idea what it is or how to replace it or check it to make sure it is bad. Info would be great. It is to the left of the throttle body next to the exhaust manifold.[img:bbe87a04d0]http://www.2carpros.com/forum/automotive_pictures/300885_0303091809_1.jpg[/img:bbe87a04d0]
Mar 3, 2009 at 10:27 AM
RHALL77
  • 3,361 POSTS
its called a fuel pressure regulator. they fail often. thats what you need to replace. good work
Mar 4, 2009 at 5:14 AM
