2005 Chevy Impala Flushing Engine Coolants
76,000 MILES • 6 CYL • FWD • AUTOMATIC
MANNYFOREVER
How often should one flush out engine coolants? What would be the best way to execute on a "how to do it yourself" level? Any Hazards or Precautions one should consider?
Apr 9, 2009 at 4:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Every 120k miles is the recommended interval. Be certain to use the correct coolant recommended for your vehicle and always use a suitable containter to recycle old coolant with. There are "Do-it-yourself" kits in most part stores that let you use a water hose and the kit to flush the vehicle's system with. Fairly simple to use, just read the instructions carefully.
Thanks for using 2CarPros.com!
Apr 9, 2009 at 5:07 PM
