2005 Chevy Impala Engine is Overheating
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
DKJ7L
The engine is fine when in motion. Once you come to stop and idle the engine is overheating.
Jan 30, 2008 at 1:44 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9f7630caad="DKJ7L"]Engine problem
2005 Chevy Impala 6 cyl Two Wheel Drive Automatic 60,000 miles
The engine is fine when in motion. Once you come to stop and idle the engine is overheating.[/quote:9f7630caad]
check coolant level and adjust if needed
check if the coolant fan working
check fuses
Jan 31, 2019 at 10:41 AM
CHEVYFAMILY
you should also check to see if air is in your coolant system my wife had the same problem, so we bled the air out of system and problem solved
