2005 Chevy Impala bump like something slips
DUMMIE
Drive Train Axles Bearings problem
2005 Chevy Impala 6 cyl Automatic 124919 miles
this car runs good somtimes ,the transmission changes out good when you start off . but when your're going down the road it will hold back or miss and sometime when you go up a little grade or a curve it will hold back or bump. had plugs and wires both changed.
Jan 28, 2009 at 4:59 AM
RHALL77
  • 3,361 POSTS
is your check engine light on? you may have a plugged fuel filter or maybe a bad cat converter.
Jan 28, 2009 at 9:47 AM
