2005 Chevy Impala brake pedal movement
2005 CHEVROLET IMPALA
DAMAGEDBODIES
Brakes problem
2005 Chevy Impala 6 cyl Two Wheel Drive Automatic 62k miles
when i apply the brakes it feels fine at first... then if i let up and apply again the pedal travels alot farther, almost to the limit. there is a noise comming from the engine that sounds like a wheering/quite clicking. the noise seems to match the rpms. about 1 month ago i noticed the brake fluid was very low. i added fluid and the level has been fine ever since, but the problem has gotten worse. i did notice the brake fluid reservoir's cap gasket has mushroomed out.
Apr 25, 2008 at 8:04 AM
MERLIN2021
  • 17,250 POSTS
If you have an expanded rubber cap seal, it's a good sign that whatever you put in that master wasn't brake fluid...you must have used a petroleum product of some type, and now ALL rubber parts will need replacing...including ABS system parts! The system is contaminated!
Apr 25, 2008 at 8:25 AM
DAMAGEDBODIES
yep luckly no abs so its cheaper
Apr 25, 2008 at 11:15 PM
