2005 Chevy Impala
GODZZZSUN
Transmission problem
2005 Chevy Impala 6 cyl Two Wheel Drive Automatic
In Nov 2009 the trans did not go in drive only in reverse. It sat until today when I started it up. I was able to drive forward around the block.I listened to hear the gears change but it was smooth. It did not rev high in first gear and stay there. I also took out the stick and smelled the fluid, it did not smell burnt.
could the problem be sensors in the trans. Thanks in advance for your answer.
Aug 30, 2010 at 1:03 PM
LEGITIMATE007
  • 5,121 POSTS
yes, is there a check engine light on?
Aug 31, 2010 at 1:06 AM
