2004 Chevy Impala will not go into overdrive
MARTHADUNN1
Transmission problem
2004 Chevy Impala 6 cyl Front Wheel Drive 70,000 miles
Have bad miles per gallon & tranny will not go into overdrive. Could this be a solenoid problem? Also had noisy fan blower; it was replaced by now takes too long to warm up
Mar 4, 2009 at 9:31 PM
BMRFIXIT
  • 19,053 POSTS
1st step is to have it scanned for codes
if tranny not shifting at the correct speeds PCM and TCM will set a trouble codes and you have to have it scanned to retrieve them code .
Code will help in pin pointing what is going on
and place to start the diagnose
blower motor
check if the fan was damaged
Mar 4, 2009 at 11:14 PM
