2004 Chevy Impala Turn signal switch
94,000 MILES • 6 CYL • FWD • AUTOMATIC
WILFAM220
How do I get the plastic cover off to replace the turn signal switch. I could get the bottom loose but couldn't get the top loose or any of it removed.
Do I need to remove steering wheel? I hope not!
Please give me a step by step to replace this switch.
Thanks and God Bless, Ken Wilson 330-209-3061
Sep 10, 2010 at 7:12 AM
  • 75,988 POSTS
Multifunction, Turn Signal Switch Replacement Removal Procedure Caution: Refer to SIR Caution in Service Precautions.
https://images.2carpros.com/forum/automotive_pictures/12900_t1_10.gif
Disable the SIR system. Remove the upper and lower trim covers. Important: The abrasion sleeve located on the steering column wire harness assembly must be reinstalled. Make note of what connector is coming out of the abrasion sleeve for installation purposes. Remove the wire harness assembly (1) from the wire harness strap (2). Disconnect the turn signal and multifunction switch assembly connector from the SIR system coil connector.
https://images.2carpros.com/forum/automotive_pictures/12900_t2_10.gif
Slide the 2 connectors (2) of the turn signal and multifunction switch assembly out of the bulkhead connector (1).
https://images.2carpros.com/forum/automotive_pictures/12900_t3_7.gif
Remove the 2 pan head tapping screws (1) and (3) from the turn signal and multifunction switch assembly (2). Remove the turn signal and multifunction switch assembly (2) from the steering column tilt head assembly. Installation Procedure
Install the turn signal and multifunction switch assembly (2) onto the steering column tilt head assembly. Notice: Refer to Fastener Notice in Service Precautions. Important: Be sure that the electrical contact of the turn signal and multifunction switch assembly (2) rests on the turn signal cancel cam assembly. Screw the 2 pan head tapping screws (1) and (3) into the turn signal and multifunction assembly (2). Tighten the top pan head tapping screw (1) to 3 Nm (27 in. lbs.) . Tighten the side pan head tapping screw (3) to 7 Nm (62 in. lbs.) .
Slide the 2 connectors (2) of the turn signal and multifunction switch assembly into the bulkhead connector (1).
Connect the turn signal and multifunction switch assembly connector to the SIR coil connector. Important: The abrasion sleeve must be installed back onto the steering column wire harness assembly. The ignition lock cylinder case wires and connector must be hanging out of the middle of the abrasion sleeve. Install the wire harness assembly (1) into the wire harness strap (2). Install the upper and lower trim covers. Enable the SIR system. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Sep 10, 2010 at 12:53 PM
