2004 Chevy Impala transmission/speedometer
88,700 MILES • 6 CYL • 2WD • AUTOMATIC
RJHORNAK
The speedometer will stick at various speeds(ex:60mph) and not return to zero. If not noticed right away, the sppedometer will continue to rise in mph every time you accelerate. To return back to zero, I can turn the car off/ then to on without starting and the speedometer will slowly (6mph each time) return to zero. It may work fine for several weeks, then do the same thing again. Is this a transmission, cable or electronic problem that I may fix myself?
Dec 28, 2009 at 7:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
suspect faulty / sticking vehicle speed sensor (VSS) located on transmission.
Dec 28, 2009 at 7:51 AM
RJHORNAK
[quote:8170c8ccea="bluelightnin6"]suspect faulty / sticking vehicle speed sensor (VSS) located on transmission.[/quote:8170c8ccea]
Yhank you, I am disabled and am hoping for a friend to replace the part soon, as I can no longer do these things myself.
Jan 5, 2010 at 5:51 AM
